Division video settings - Printable Version
+--- Forum: Shooting (https://forum.bug-community.com/Forum-Shooting)
+--- Thread: Division video settings (/Thread-Division-video-settings)
Division video settings - Anubis_offline - 07-12-2016
Voor al de BuG leden die The Division spelen Smile.
Video settings Custom"
V-sync mode: "Off" (turn on only if you have a high end GPU. Prevents screen tearing, but requires your GPU to render multiple frames at once.)
Frame rate limit: "off" (this is our goal frame rate. Monitors run native 60hz in the US. Anything higher isn't scene just buffered. This will prevent your GPU from wildly jumping fps triggering your GPU to cause tearing, overuse, and variable fan speeds. Use 30fps if you can not reach anything higher)
Shadow quality: "Low" (Shadow cast on world objects. Effects the detail of them as well as what objects will have one. Raising this setting to the Nvidia option gives more depth, but nothing worth the FPS drop)
Shadow resolution: "High" (detail and definition of world shadows. Lowering looks too jaggy and moosh for the marginal FPS gain)
Spot Shadow count: "Medium" (How many shadows that will cast on screen from NPCs and i believe the cars? Lower if you start to lose fps when several characters on screen have shadows)
Spot shadow resolution: "Ultra" (detail and definition of your NPC shadows and other players. Anything lower and your character shadow looks like smeared poop on a wall for the marginal fps boost.)
Contact Shadows: "Sun Low" (Anything higher shows marginal gains)
Post FX AA: "Off" (Don't recommend as the game does a good job already with jaggies)
Temporal AA: "Supersampling" (I still need to trial/ error this setting, but this seems to give better FPS. I don't notice a difference between the two options for this category)
Resolution scale: "85%" (This reduces the pixel count generated on screen. Can help with Vram issues, and reduces workload for the GPU to render each pixel. I personally set this to 75% as it doesn't reduce fidelity for me enough for the TREMENDOUS FPS boost I gain from it. The consensus is 100% as it's the native pixel count for the resolution you've set. Though, I highly encourage at least dropping it to 85%. It helps a ton, fidelity isn't lost, and it doesn't create a huge issue with pixelation on account you're moving a lot in this game. A good balance for anyone struggling with FPS after all the calibrations. Don't go lower then 75%. It gets awful then lol.)
Sharpen image: "100%" (This is up to personal preference. This is a Post FX effect and doesn't impact FPS. Helps remove Jaggies on screen if lowered)
Particle detail: "High" (I compared each option to the smoke coming out of vents. Dropping below high will show some lowering of particle effects. Though, if you have issues during firefights/ walking through smoke. Drop this to low. Medium/ low show no difference in quality.)
Enable wind-affected snow: "Yes" (Uses physics engine in cpu or GPU depending. I see no drop in FPS when on or off. So leave on for fideltiy)
Volumetric fog: "High" (MAJOR FPS GAINS if set to medium. It's hard to see a difference between the highest setting with this, but CHUGS when set to max. Drop down for little fidelity loss)
Reflection Quality: "High" (Shows detail in water reflections and windows. I set this to high since there is no fps loss from the option.)
Local Reflection Quality: "Low" (Shows the reflection in puddles of objects and props/ npcs. Set it low without any crazy difference in fidelity unless you stare all day)
Sub-surface scattering: "Yes" (I leave this on when I can. I don't receive an FPS Gain or drop disabling. Bounces the light off skin to make it look peachy Puh2)
Anisotropic filtering: "16x" (I don't believe anyone should have this any lower. GPUs for years have no issues with this option maxed)
Parallax mapping: "High" (I see no difference in my FPS requiring this to be off. Gives great depth to textures. Too good to sacrifice.)
Ambient occlusion: "Low" (Decent FPS Gains here. NVIDIAs option does give better results, but destroys fps to where the marginal fidelity increase isn't worth it. High/ medium show zero differences to low. Turn this setting off if you have fps troubles even further)
Depth of field: "Off" (I love this setting in games. Creates great depth with character interactions, but isn't worth the FPS drops Frown. Turning this off will help raise FPS in the menus and augmented menu on your arm. if you must have this setting on medium/ high show no difference. Set to medium then.)
Object detail: "10%" (I'm still tinkering with these settings. The sweet spot is just around 50% for a good distance ratio where you wont really see any close pop in textures/ mooshy ones.)
Extra streaming distance: "60%" (I set this to where you can see far enough to make the game have some depth and character, but doesn't lose too much. A user did point out this gave huge fps gains when dropped around 10%. So trial and error if need be.)
Chromatic aberration: "Off" (Negligible FPS gains if off. Post FX i believe. Gives you the impression you're looking through a lens from a camera giving you a "rainbow effect" around edges)
Lens flare: "On" (Negligible FPS gains if off. Some find them annoying "JJ Abrams" though???)
Vignette effect: "Off" (Post FX. No FPS impact. Comes to personal preference)
